just curious, what do you run that model on for HA decoding ?All 6 of my cams are Dahua 5231-ze.
I’ve been having these app crashes where the service stops but then is restarted for months now so I do t think it’s related to the latest or the version you regressed back to.
Just checked my emails and I emailed support back in 13/01/2020 when the system was running Version: Release 5.0.8.0 x64
same here... 28 cameras, mostly Dauha + a couple of HikI have it set to Intel within the main Cameras settings tab, all the cameras then pick up this as their default.
What cameras are you using?Hi all (especially Fenderman), I have 10 cameras, my PC is an i7, plenty of ram, CPU usage is about 60%. I was able to change 1 camera to the substream and it dropped the CPU usage like 6% but on the other cameras I can not figure out what parameters I put in the substream box. I pasted the mainstream numbers in the substream box and changed some of the numbers 1 to a 2, 101 toa 102 but no luck getting the substream to go. Here are a few of my MAIN stram parameters, any help ouyt there what to try for sub stream:
/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
/Streaming/Channels/101?transportmode=unicast&profile=Profile_1
Any help appreciated!
Thanks,
Adam
Thanks,
Adam
have you enabled sub-streams in the cameras?Rats, tried both, still only the MAIN stream. Adam
on my 4k Hik cameras I have just / as the main stream and /streaming/channels/2 as the substreamYes, I checked, they have all been enabled since day 1.
