reset ip cam CTRONICS CTIPC-224C720PWS Hi3518
procsacs
Jun 28, 2023
1
Space
Hi all, i have ip cam CTRONICS CTIPC-224C720PWS on Hi3518 chip, and the camera seems to work, assigns an IP address LAN (wifi off?), but all ports are blocked, there is no access, the only thing is the camera records it to the SD card and it works.
I connected TTL USB but no root password works. How to reset the camera to factory settings, it does not respond to the RESET button. Can anyone suggest something
Code:
U-Boot 2010.06 (Apr 14 2015 - 03:05:00)
Check spi flash controller v350... Found
Spi(cs1) ID: 0xC8 0x40 0x18 0xC8 0x40 0x18
Spi(cs1): Block:64KB Chip:16MB Name:"GD25Q128"
In:    serial
Out:   serial
Err:   serial
Hit any key to stop autoboot:  0
16384 KiB hi_sfc at 0:0 is now current device
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-3.0.8
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1527540 Bytes = 1.5 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 ([email protected]) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #3 Tue Apr 14 03:16:36 HKT 2015
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: hi3518
Memory policy: ECC disabled, Data cache writeback
AXI bus clock 200000000.
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 11176
Kernel command line: mem=44M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=jffs2 mtdparts=hi_sfc:512K(boot),1536K(kernel),14M(rootfs)
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 44MB = 44MB total
Memory: 40788k/40788k available, 4268k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xc3000000 - 0xfe000000   ( 944 MB)
    lowmem  : 0xc0000000 - 0xc2c00000   (  44 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc001f000   (  92 kB)
      .text : 0xc001f000 - 0xc0393000   (3536 kB)
      .data : 0xc0394000 - 0xc03abae0   (  95 kB)
       .bss : 0xc03abb04 - 0xc03bc890   (  68 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:32 nr_irqs:32 32
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 42949ms
Calibrating delay loop... 218.72 BogoMIPS (lpj=1093632)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Serial: AMBA PL011 UART driver
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 5) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 5) is a PL011 rev2
uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 25) is a PL011 rev2
bio: create slab <bio-0> at 0
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource timer1
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 79
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
Spi id table Version 1.22
SPI FLASH start_up_mode is 3 Bytes
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
3 cmdlinepart partitions found on MTD device hi_sfc
Creating 3 MTD partitions on "hi_sfc":
0x000000000000-0x000000080000 : "boot"
0x000000080000-0x000000200000 : "kernel"
0x000000200000-0x000001000000 : "rootfs"
Fixed MDIO Bus: probed
himii: probed
usbmon: debugfs is not available
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
hiusb-ehci hiusb-ehci.0: HIUSB EHCI
hiusb-ehci hiusb-ehci.0: new USB bus registered, assigned bus number 1
hiusb-ehci hiusb-ehci.0: irq 15, io mem 0x100b0000
hiusb-ehci hiusb-ehci.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
hiusb-ohci hiusb-ohci.0: HIUSB OHCI
hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 2
hiusb-ohci hiusb-ohci.0: irq 16, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
TCP cubic registered
NET: Registered protocol family 10
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
registered taskstats version 1
▒mmc0: new high speed SDHC card at address 0001
mmcblk0: mmc0:0001 SD 14.7 GiB
 mmcblk0: p1
usb 1-1: new high speed USB device number 2 using hiusb-ehci
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006ca268: 0x1981 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006ca270: 0xbb19 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006ca274: 0x009a instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006ca278: 0x0009 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006ca27c: 0x81bb instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006ca288: 0xbb82 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006ca28c: 0x891b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006ca290: 0x891b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006ca2a0: 0xbb00 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006ca2a8: 0x80a2 instead
Further such events for this erase block will not be printed
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006e4ff4: 0x1981 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006e4ffc: 0xbb19 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006e5000: 0x0323 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006e5004: 0x0001 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006e5008: 0x81a0 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006e5014: 0x00a3 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006e5018: 0x00a3 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006e501c: 0x00a3 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006e5034: 0x98a2 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006e5038: 0x1981 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00cd1150: 0x1981 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00cd1154: 0x002b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00cd1158: 0x2aa2 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00cd115c: 0x0216 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00cd1160: 0x0241 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00cd1164: 0x021d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00cd1168: 0x033b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00cd116c: 0x0a03 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00cd1170: 0xfb33 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00cd1174: 0x4def instead
VFS: Mounted root (jffs2 filesystem) on device 31:2.
Freeing init memory: 92K
            _ _ _ _ _ _ _ _ _ _ _ _
            \  _  _   _  _ _ ___
            / /__/ \ |_/
           / __   /  -  _ ___
  _ _ _ _/ /  /  \_/  \_ ______
___________\___\__________________
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
udevd (284): /proc/284/oom_adj is deprecated, please use /proc/284/oom_score_adj instead.
[RCS]: /etc/init.d/S80network
ADDRCONF(NETDEV_UP): eth0: link is not ready
sd
sd
dosfsck 3.0.0, 28 Sep 2008, FAT32, LFN
(none) login: PHY: himii:00 - Link is Up - 100/Full
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
/dev/mmcblk0p1: 4 files, 5/483718 clusters
Check sd card OK!
sinit driver init successful!
mt7601Usta: module license 'unspecified' taints kernel.
Disabling lock debugging due to kernel taint
rtusb init rtusbSTA --->
=== pAd = c32f4000, size = 899480 ===
<-- RTMPAllocTxRxRingMemory, Status=0
<-- RTMPAllocAdapterBlock, Status=0
RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x8
RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x4
RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x5
RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x6
RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x7
RTMP_COM_IoctlHandle():pAd->BulkOutEpAddr=0x9
NVM is EFUSE
Endpoint(8) is for In-band Command
Endpoint(4) is for WMM0 AC0
Endpoint(5) is for WMM0 AC1
Endpoint(6) is for WMM0 AC2
Endpoint(7) is for WMM0 AC3
Endpoint(9) is for WMM1 AC0
Endpoint(84) is for Data-In
Endpoint(85) is for Command Rsp
usbcore: registered new interface driver rtusbSTA
extalarm driver init successful  !
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0, nodeamon= 0)
encript driver init successful!
relay driver init successful!
reset driver init successful!
rled driver init successful!
ircut driver init successful!
saradc driver init successful!
rs485 driver init successful!
light driver init successful  !
Hisilicon Media Memory Zone Manager
insmod: can't insert 'hi3518_base.ko': invalid module format
hi3518_sys: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_sys: Unknown symbol CMPI_StopModules (err 0)
hi3518_sys: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_sys: Unknown symbol CMPI_UserCopy (err 0)
hi3518_sys: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_sys: Unknown symbol CMPI_CreateProc (err 0)
hi3518_sys: Unknown symbol CMPI_ExitModules (err 0)
hi3518_sys: Unknown symbol g_aModName (err 0)
hi3518_sys: Unknown symbol CMPI_InitModules (err 0)
hi3518_sys: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_sys: Unknown symbol CMPI_QueryModules (err 0)
hi3518_sys: Unknown symbol g_proc_enable (err 0)
hi3518_sys: Unknown symbol HI_LOG (err 0)
hi3518_sys: Unknown symbol CMPI_MmzFree (err 0)
hi3518_sys: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_sys: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_sys.ko': unknown symbol in module, or unknown parameter
hi3518_dsu: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_dsu: Unknown symbol VB_UserAdd (err 0)
hi3518_dsu: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_dsu: Unknown symbol VB_UserSub (err 0)
hi3518_dsu: Unknown symbol CMPI_CreateProc (err 0)
hi3518_dsu: Unknown symbol g_astModules (err 0)
hi3518_dsu: Unknown symbol VB_GetBlkBySize (err 0)
hi3518_dsu: Unknown symbol g_aModName (err 0)
hi3518_dsu: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_dsu: Unknown symbol g_proc_enable (err 0)
hi3518_dsu: Unknown symbol HI_LOG (err 0)
hi3518_dsu: Unknown symbol VB_Handle2Kern (err 0)
hi3518_dsu: Unknown symbol VB_Handle2PoolId (err 0)
hi3518_dsu: Unknown symbol VB_Handle2Phys (err 0)
insmod: can't insert 'hi3518_dsu.ko': unknown symbol in module, or unknown parameter
hi3518_viu: Unknown symbol g_u32FuncId (err 0)
hi3518_viu: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_viu: Unknown symbol VB_UserAdd (err 0)
hi3518_viu: Unknown symbol CMPI_UserCopy (err 0)
hi3518_viu: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_viu: Unknown symbol VB_UserSub (err 0)
hi3518_viu: Unknown symbol CMPI_CreateProc (err 0)
hi3518_viu: Unknown symbol g_astModules (err 0)
hi3518_viu: Unknown symbol VB_GetBlkBySize (err 0)
hi3518_viu: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_viu: Unknown symbol VB_IsBlkValid (err 0)
hi3518_viu: Unknown symbol g_proc_enable (err 0)
hi3518_viu: Unknown symbol HI_LOG (err 0)
hi3518_viu: Unknown symbol VB_Handle2Kern (err 0)
hi3518_viu: Unknown symbol VB_Handle2PoolId (err 0)
hi3518_viu: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_viu: Unknown symbol VB_Handle2Phys (err 0)
hi3518_viu: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_viu.ko': unknown symbol in module, or unknown parameter
hi3518_isp: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_isp: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_isp: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_isp: Unknown symbol CMPI_CreateProc (err 0)
hi3518_isp: Unknown symbol g_astModules (err 0)
hi3518_isp: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_isp: Unknown symbol g_proc_enable (err 0)
hi3518_isp: Unknown symbol CMPI_MmzFree (err 0)
insmod: can't insert 'hi3518_isp.ko': unknown symbol in module, or unknown parameter
hi3518_vpss: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_vpss: Unknown symbol VB_UserAdd (err 0)
hi3518_vpss: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_vpss: Unknown symbol CMPI_UserCopy (err 0)
hi3518_vpss: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_vpss: Unknown symbol VB_UserSub (err 0)
hi3518_vpss: Unknown symbol CMPI_CreateProc (err 0)
hi3518_vpss: Unknown symbol g_astModules (err 0)
hi3518_vpss: Unknown symbol VB_GetBlkBySize (err 0)
hi3518_vpss: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_vpss: Unknown symbol VB_IsBlkValid (err 0)
hi3518_vpss: Unknown symbol g_proc_enable (err 0)
hi3518_vpss: Unknown symbol HI_LOG (err 0)
hi3518_vpss: Unknown symbol CMPI_MmzFree (err 0)
hi3518_vpss: Unknown symbol VB_Handle2Kern (err 0)
hi3518_vpss: Unknown symbol VB_Handle2PoolId (err 0)
hi3518_vpss: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_vpss: Unknown symbol VB_Handle2Phys (err 0)
hi3518_vpss: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_vpss.ko': unknown symbol in module, or unknown parameter
hi3518_venc: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_venc: Unknown symbol CMPI_UserCopy (err 0)
hi3518_venc: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_venc: Unknown symbol CMPI_CreateProc (err 0)
hi3518_venc: Unknown symbol g_astModules (err 0)
hi3518_venc: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_venc: Unknown symbol g_proc_enable (err 0)
hi3518_venc: Unknown symbol HI_LOG (err 0)
hi3518_venc: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_venc: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_venc.ko': unknown symbol in module, or unknown parameter
hi3518_group: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_group: Unknown symbol VB_UserAdd (err 0)
hi3518_group: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_group: Unknown symbol CMPI_UserCopy (err 0)
hi3518_group: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_group: Unknown symbol VB_UserSub (err 0)
hi3518_group: Unknown symbol CMPI_CreateProc (err 0)
hi3518_group: Unknown symbol g_astModules (err 0)
hi3518_group: Unknown symbol VB_GetBlkBySize (err 0)
hi3518_group: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_group: Unknown symbol VB_IsBlkValid (err 0)
hi3518_group: Unknown symbol g_proc_enable (err 0)
hi3518_group: Unknown symbol HI_LOG (err 0)
hi3518_group: Unknown symbol CMPI_MmzFree (err 0)
hi3518_group: Unknown symbol VB_Handle2Kern (err 0)
hi3518_group: Unknown symbol VB_Handle2PoolId (err 0)
hi3518_group: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_group: Unknown symbol VB_Handle2Phys (err 0)
hi3518_group: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_group.ko': unknown symbol in module, or unknown parameter
hi3518_chnl: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_chnl: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_chnl: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_chnl: Unknown symbol CMPI_CreateProc (err 0)
hi3518_chnl: Unknown symbol g_astModules (err 0)
hi3518_chnl: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_chnl: Unknown symbol g_proc_enable (err 0)
hi3518_chnl: Unknown symbol HI_LOG (err 0)
hi3518_chnl: Unknown symbol CMPI_MmzFree (err 0)
insmod: can't insert 'hi3518_chnl.ko': unknown symbol in module, or unknown parameter
hi3518_h264e: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_h264e: Unknown symbol VB_UserAdd (err 0)
hi3518_h264e: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_h264e: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_h264e: Unknown symbol VB_UserSub (err 0)
hi3518_h264e: Unknown symbol CMPI_CreateProc (err 0)
hi3518_h264e: Unknown symbol g_astModules (err 0)
hi3518_h264e: Unknown symbol VB_GetBlkByPoolId (err 0)
hi3518_h264e: Unknown symbol VB_CreatePool (err 0)
hi3518_h264e: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_h264e: Unknown symbol g_proc_enable (err 0)
hi3518_h264e: Unknown symbol HI_LOG (err 0)
hi3518_h264e: Unknown symbol CMPI_MmzFree (err 0)
hi3518_h264e: Unknown symbol VB_Handle2Kern (err 0)
hi3518_h264e: Unknown symbol VB_Handle2BlkSize (err 0)
hi3518_h264e: Unknown symbol VB_Handle2PoolId (err 0)
hi3518_h264e: Unknown symbol VencBufferCache (err 0)
hi3518_h264e: Unknown symbol VB_DestroyPool (err 0)
hi3518_h264e: Unknown symbol VB_Handle2Phys (err 0)
insmod: can't insert 'hi3518_h264e.ko': unknown symbol in module, or unknown parameter
hi3518_jpege: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_jpege: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_jpege: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_jpege: Unknown symbol CMPI_CreateProc (err 0)
hi3518_jpege: Unknown symbol g_astModules (err 0)
hi3518_jpege: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_jpege: Unknown symbol g_proc_enable (err 0)
hi3518_jpege: Unknown symbol HI_LOG (err 0)
hi3518_jpege: Unknown symbol CMPI_MmzFree (err 0)
hi3518_jpege: Unknown symbol VencBufferCache (err 0)
insmod: can't insert 'hi3518_jpege.ko': unknown symbol in module, or unknown parameter
hi3518_rc: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_rc: Unknown symbol VB_UserAdd (err 0)
hi3518_rc: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_rc: Unknown symbol VB_UserSub (err 0)
hi3518_rc: Unknown symbol CMPI_CreateProc (err 0)
hi3518_rc: Unknown symbol g_astModules (err 0)
hi3518_rc: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_rc: Unknown symbol g_proc_enable (err 0)
hi3518_rc: Unknown symbol HI_LOG (err 0)
insmod: can't insert 'hi3518_rc.ko': unknown symbol in module, or unknown parameter
hi3518_region: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_region: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_region: Unknown symbol CMPI_UserCopy (err 0)
hi3518_region: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_region: Unknown symbol CMPI_CreateProc (err 0)
hi3518_region: Unknown symbol g_astModules (err 0)
hi3518_region: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_region: Unknown symbol g_proc_enable (err 0)
hi3518_region: Unknown symbol HI_LOG (err 0)
hi3518_region: Unknown symbol CMPI_MmzFree (err 0)
hi3518_region: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_region: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_region.ko': unknown symbol in module, or unknown parameter
hi3518_vda: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_vda: Unknown symbol VB_UserAdd (err 0)
hi3518_vda: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_vda: Unknown symbol CMPI_UserCopy (err 0)
hi3518_vda: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_vda: Unknown symbol VB_UserSub (err 0)
hi3518_vda: Unknown symbol CMPI_CreateProc (err 0)
hi3518_vda: Unknown symbol g_astModules (err 0)
hi3518_vda: Unknown symbol VB_GetBlkBySize (err 0)
hi3518_vda: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_vda: Unknown symbol g_proc_enable (err 0)
hi3518_vda: Unknown symbol HI_LOG (err 0)
hi3518_vda: Unknown symbol CMPI_MmzFree (err 0)
hi3518_vda: Unknown symbol VB_Handle2Kern (err 0)
hi3518_vda: Unknown symbol VB_Handle2PoolId (err 0)
hi3518_vda: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_vda: Unknown symbol VB_Handle2Phys (err 0)
hi3518_vda: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_vda.ko': unknown symbol in module, or unknown parameter
hi3518_ive: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_ive: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_ive: Unknown symbol CMPI_UserCopy (err 0)
hi3518_ive: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_ive: Unknown symbol CMPI_CreateProc (err 0)
hi3518_ive: Unknown symbol g_astModules (err 0)
hi3518_ive: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_ive: Unknown symbol g_proc_enable (err 0)
hi3518_ive: Unknown symbol HI_LOG (err 0)
hi3518_ive: Unknown symbol CMPI_MmzFree (err 0)
hi3518_ive: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_ive: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_ive.ko': unknown symbol in module, or unknown parameter
hi_i2c: Unknown symbol g_stIspExpFunc (err 0)
insmod: can't insert 'extdrv/hi_i2c.ko': unknown symbol in module, or unknown parameter
sh: 1: unknown operand
sh: 2: unknown operand
sh: 3: unknown operand
sh: 11: unknown operand
sh: 5: unknown operand
sh: 10: unknown operand
sh: 12: unknown operand
sh: 13: unknown operand
sh: 14: unknown operand
ssp_ad9020: Unknown symbol g_stIspExpFunc (err 0)
insmod: can't insert 'extdrv/ssp_ad9020.ko': unknown symbol in module, or unknown parameter
acodec: Unknown symbol CMPI_RemoveProc (err 0)
acodec: Unknown symbol CMPI_CreateProc (err 0)
acodec: Unknown symbol g_astModules (err 0)
acodec: Unknown symbol g_proc_enable (err 0)
insmod: can't insert 'acodec.ko': unknown symbol in module, or unknown parameter
hi3518_sio: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_sio: Unknown symbol g_astModules (err 0)
hi3518_sio: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_sio: Unknown symbol HI_LOG (err 0)
insmod: can't insert 'hi3518_sio.ko': unknown symbol in module, or unknown parameter
hi3518_ai: Unknown symbol AiCheckCodecNoise (err 0)
hi3518_ai: Unknown symbol VB_InquirePoolUserCnt (err 0)
hi3518_ai: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_ai: Unknown symbol VB_UserAdd (err 0)
hi3518_ai: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_ai: Unknown symbol CMPI_UserCopy (err 0)
hi3518_ai: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_ai: Unknown symbol VB_UserSub (err 0)
hi3518_ai: Unknown symbol CMPI_CreateProc (err 0)
hi3518_ai: Unknown symbol g_astModules (err 0)
hi3518_ai: Unknown symbol VB_GetBlkByPoolId (err 0)
hi3518_ai: Unknown symbol VB_CreatePool (err 0)
hi3518_ai: Unknown symbol AiGetDMAChn (err 0)
hi3518_ai: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_ai: Unknown symbol VB_IsBlkValid (err 0)
hi3518_ai: Unknown symbol g_proc_enable (err 0)
hi3518_ai: Unknown symbol HI_LOG (err 0)
hi3518_ai: Unknown symbol CMPI_MmzFree (err 0)
hi3518_ai: Unknown symbol VB_Handle2Kern (err 0)
hi3518_ai: Unknown symbol VB_Handle2PoolId (err 0)
hi3518_ai: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_ai: Unknown symbol VB_DestroyPool (err 0)
hi3518_ai: Unknown symbol VB_Handle2Phys (err 0)
hi3518_ai: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_ai.ko': unknown symbol in module, or unknown parameter
hi3518_ao: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_ao: Unknown symbol AoGetDMAChn (err 0)
hi3518_ao: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_ao: Unknown symbol CMPI_UserCopy (err 0)
hi3518_ao: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_ao: Unknown symbol CMPI_CreateProc (err 0)
hi3518_ao: Unknown symbol g_astModules (err 0)
hi3518_ao: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_ao: Unknown symbol g_proc_enable (err 0)
hi3518_ao: Unknown symbol HI_LOG (err 0)
hi3518_ao: Unknown symbol CMPI_MmzFree (err 0)
hi3518_ao: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_ao: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_ao.ko': unknown symbol in module, or unknown parameter
hi3518_aenc: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_aenc: Unknown symbol VB_UserAdd (err 0)
hi3518_aenc: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_aenc: Unknown symbol CMPI_UserCopy (err 0)
hi3518_aenc: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_aenc: Unknown symbol VB_UserSub (err 0)
hi3518_aenc: Unknown symbol CMPI_CreateProc (err 0)
hi3518_aenc: Unknown symbol g_astModules (err 0)
hi3518_aenc: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_aenc: Unknown symbol VB_IsBlkValid (err 0)
hi3518_aenc: Unknown symbol g_proc_enable (err 0)
hi3518_aenc: Unknown symbol HI_LOG (err 0)
hi3518_aenc: Unknown symbol CMPI_MmzFree (err 0)
hi3518_aenc: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_aenc: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_aenc.ko': unknown symbol in module, or unknown parameter
hi3518_adec: Unknown symbol CMPI_RegisterMod (err 0)
hi3518_adec: Unknown symbol CMPI_MmzMalloc (err 0)
hi3518_adec: Unknown symbol CMPI_UserCopy (err 0)
hi3518_adec: Unknown symbol CMPI_RemoveProc (err 0)
hi3518_adec: Unknown symbol CMPI_CreateProc (err 0)
hi3518_adec: Unknown symbol g_astModules (err 0)
hi3518_adec: Unknown symbol CMPI_UnRegisterMod (err 0)
hi3518_adec: Unknown symbol g_proc_enable (err 0)
hi3518_adec: Unknown symbol HI_LOG (err 0)
hi3518_adec: Unknown symbol CMPI_MmzFree (err 0)
hi3518_adec: Unknown symbol CMPI_UnRegisterDevice (err 0)
hi3518_adec: Unknown symbol CMPI_RegisterDevice (err 0)
insmod: can't insert 'hi3518_adec.ko': unknown symbol in module, or unknown parameter
insert audio
==== Your input Sensor type is icx692 ====
1. LDO_CTR0(6c) = a64799, PMU_OCLEVEL c
2. LDO_CTR0(6c) = a6478d, PMU_OCLEVEL 6
FW Version:0.1.00 Build:7640
Build Time:201308222153____
ILM Length = 47000(bytes)
DLM Length = 0(bytes)
Loading FW....
RTMP_TimerListAdd: add timer obj c337e1ac!
RTMP_TimerListAdd: add timer obj c337e1c4!
RTMP_TimerListAdd: add timer obj c337e1dc!
RTMP_TimerListAdd: add timer obj c337e194!
RTMP_TimerListAdd: add timer obj c337e14c!
RTMP_TimerListAdd: add timer obj c337e164!
RTMP_TimerListAdd: add timer obj c3312fe4!
RTMP_TimerListAdd: add timer obj c32f61e0!
RTMP_TimerListAdd: add timer obj c32f61fc!
RTMP_TimerListAdd: add timer obj c331303c!
RTMP_TimerListAdd: add timer obj c32f8bb4!
RTMP_TimerListAdd: add timer obj c32f8264!
RTMP_TimerListAdd: add timer obj c32f8b98!
RTMP_TimerListAdd: add timer obj c32f8dd8!
RTMP_TimerListAdd: add timer obj c32f8bd0!
RTMP_TimerListAdd: add timer obj c32f8bec!
RTMP_TimerListAdd: add timer obj c32f8c08!
RTMP_TimerListAdd: add timer obj c3312fb4!
RTMP_TimerListAdd: add timer obj c3313024!
RTMP_TimerListAdd: add timer obj c32f8e08!
RTMP_TimerListAdd: add timer obj c32f8e20!
RTMP_TimerListAdd: add timer obj c32f8e38!
RTMP_TimerListAdd: add timer obj c32f8e50!
cfg_mode=9
wmode_band_equal(): Band Equal!
Key1Str is Invalid key length(0) or Type(0)
Key2Str is Invalid key length(0) or Type(0)
Key3Str is Invalid key length(0) or Type(0)
Key4Str is Invalid key length(0) or Type(0)
1. Phy Mode = 14
2. Phy Mode = 14
NVM is Efuse and its size =1d[1e0-1fc]
3. Phy Mode = 14
AntCfgInit: primary/secondary ant 0/1
---> InitFrequencyCalibration
InitFrequencyCalibrationMode:Unknow mode = 3
InitFrequencyCalibration: frequency offset in the EEPROM = 104(0x68)
<--- InitFrequencyCalibration
RTMPSetPhyMode: channel is out of range, use first channel=1
MCS Set = ff 00 00 00 00
<==== rt28xx_init, Status=0
0x1300 = 00064300
RTMPDrvOpen(1):Check if PDMA is idle!
RTMPDrvOpen(2):Check if PDMA is idle!
motor driver init successful!
enew
speed: 100, duplex: 1
killall: udhcpc: no process killed
udhcpc (v1.16.1) started
dhcp failed. set eth0 to default ip: 192.168.1.88
killall: runarp: no process killed
Sending discover...
Sending select for 192.168.1.220...
killall: arping: no process killed
Lease of 192.168.1.220 obtained, lease time 86400
deleting routers
route: SIOCDELRT: No such process
adding dns 8.8.8.8
adding dns 8.8.4.4
1
2
 RTC time 1970-01-01 00:26:52
Set system time as date -s 1970.01.01-00:26:52
date: can't set date: Invalid argument
Thu Jan  1 00:26:52 STD 1970
umount: can't forcibly umount /mnt/mtd/ipc/tmpfs/sd: Invalid argument
killall: gerddns: no process killed
killall: upnp_map: no process killed
killall: ddns_update: no process killed
