PSA: Ubiquiti Network compromised again | Critical UniFi OS bug lets hackers gain root without authentication
Arjun
14,078
16,402
The Free? World
Update your devices ASAP!
Reactions: Techie007L
The exploits only work if you allow access to your console from outside world. NEVER DO THAT!
That means DISABLE REMOTE MANAGEMENT / REMOTE LOGIN found under console settings, enabled by default outside the box :lol:
Not exactly , it's mainly about Direct Remote Connection (what is basically port forwarding to console WebUI :facepalm:), but disabling Remote Access completely is not a bad idea.
Only VPN, preferably Wireguard or some Wireguard based Unifi tools such as teleport or site magic.
  • Exclamation
Reactions: Arjun
