How to use the camera in Blue iris
Cor
May 5, 2017
184
19
Greetings,
Some years ago I bought this small camera:
Never used , but now I have a use for it.
I would like to add this camera in blue iris ... but how?
-In the VMS software delivered on a CD I can view the camera and is working.
-When I logon ( try to) via the Ip adress in a webbrowser, everything is in Chinese.
-These are the settings in the VMS software:
Blue iris finds the camera, says here en there "OK" when I click find/inspect.
But the outcome is "No signal" when I want to view the camera.
Anyone has an idea?
many thanks,
Cor
Try this format:
Code:
http://yourcam-IP/user=[username]_password=[password]_channel=1_stream=0.sdp?real_stream
Sub your cam IP and your username and password for [username] and [password]. FYI, my cam is 'admin' and no password.
Reactions: fenderman
YES!!!! .
Awesome , many thanks!
The whole GUI is in Chinese , any option to change it in english? or any "security options" I need to change?
Thanks,
Cor
YES!!!! .
Thanks,
Cor
Glad I could help.
Re: the cam's webGUI; when I launch mine, I get the following screen with a language selection upper right...insure your browser is maximized (no scroll bars), not zoomed (at 100%) and also try (possibly) IE11.
awesome , yes , I initially did it in Chrome , and no language bar . In explorere I could choose al lot of different languages.
Many thanks,
Cor
Reactions: TonyR
Many thanks,
Cor
Great! I'm 2 for 2..not bad ( I have done much worse). :highfive:
