Did you also change the highlighted to MyModels. After all the changes make sure you reboot the PC
yep I have updated it. Extremely Odd theres a vehicle there and it doesnt detect.
14 cameras, no issue with Deepstack non custom models.15,000ms is a long time and certainly why it is timing out.
How many cameras are you running DS on?
Cheers! Just formatted. Is it best to install DeepStack and cuda first or Blue iris first... Hopefully this fixes custom models if not I'm out of ideas.Don't forget to deactivate BI before you reformat and make a note of you license number, hard copy.
ThanksI would install in this order Blue Iris, cuda, DeepStack.
Do you have DeepStack working without any custom models?Thanks
CUDA 10.1 from NVIDIA downloaded
cuDNN v8.3.1 (November 22nd, 2021), for CUDA 10.2 downloaded.
Did everyone else install the patches for CUDA 10.1? CUDA 10.1 Update 2 Now Available | NVIDIA Developer Blog
In another thread I downloaded Patch 1 & 2 for CUDA 10.1. Wonder if that was the underlying issue.
