S samantha.gorman23 n3wb Jun 19, 2024 4 0 Manchester Jun 19, 2024 #1 Dahua timeline has changed buttons missing to extend timeline for easy view and keeps jumping time too easily
samplenhold IPCT+ Member Aug 8, 2018 8,553 30,436 Spring, Texas Jun 19, 2024 #2 Is there a question in there? Reactions: bigredfish
S samantha.gorman23 n3wb Jun 19, 2024 4 0 Manchester Jun 19, 2024 #3 Yes, how do I get the button back as the timeline keeps jumping, I can't cut videos without it
bigredfish Known around here Sep 5, 2016 26,340 69,460 The Swamp Jun 19, 2024 #4 In what? The NVR? SmartPSS? DMSS ? Reactions: samplenhold
S samantha.gorman23 n3wb Jun 19, 2024 4 0 Manchester Jun 20, 2024 #5 bigredfish said: In what? The NVR? SmartPSS? DMSS ? Click to expand... I'm Not a expert sorry, it's on the nvr when viewing footage on the time line
bigredfish Known around here Sep 5, 2016 26,340 69,460 The Swamp Jun 20, 2024 #6 Did you update the firmware or change browsers you were using? If you don’t use the IE browser, certain buttons do not appear. Reactions: StevenFromTexas
S samantha.gorman23 n3wb Jun 19, 2024 4 0 Manchester Jun 21, 2024 #7 bigredfish said: Did you update the firmware or change browsers you were using? If you don’t use the IE browser, certain buttons do not appear. Click to expand... Hi, I'm viewing from the box onto my TV
