Hallo, I bought XVR5116HS-X because I have to use some legacy CVBS cameras and I want to use new IP ones as well. Now i am testing the device.
The problem i am having is that when I set up cam1 to cam15 as Analog (or auto) and the 16th one as IP I get diferent result compare Live View vs SmartPSS.
Dahua Live View over IE shows cameras as expected - I get 16 cams and the one IP cam is last. When I look throught SmartPSS I can see that first analog camera is missing. The rest is ok.
Note that IPcam 16th doesnt show picture as I dont have valid setting on it. I dont see why that should be a reason for the first one in SmartPSS missing thought.
Could you tel me why the first one is missing in SmartPSS???
Will appreciate any suggestion. Thank You. Pavel
