XVR5104HS-4KL-I3 UART pin out
amijim
Mar 28, 2018
8
3
Hello there I am Dimitris and since June I upgraded my xvr 1080p to 4k alon with new cameras.Everything was working ok but I installed a wrong firmware and now the p2p does not work plus a I get very bad quality on my cams.Now I have the correct upgraded firmware but the automated updater complains that it is the wrong version.I would like to do it by the UART method but I cannot locate the UART pins.Doea any one know where it is located on a xvr5104hs 4kl i3? I see no sign of serial.Is there any other way to bypass the file warning and get it flashed?.thank you.
