- Jan 28, 2017
- 1,211
- 472
Hi, I have a laptop from 2011. I booted it up and loaded Windows 10 Pro x64 on it and BI and so far works well but trying to see if it will work with more computers.
I want to run 6-8 IPCAMTALK cameras:
https://store.ipcamtalk.com/
-not sure on which model yet. But thinking about the 8MP(4K) 6 to start.
Stats on laptop:
core i7 - 2820qm @ 2.30ghmz (has quick sync enabled and working)
8GB DDR3 RAM
Windows 10 PRO 64x
256gb SAMSUNG SSD
The laptop as an ethernet adapter.
External HD WAS GOING TO DO 10TB WD PURPLE in this contraption:
https://www.amazon.com/gp/product/B01E80N2E8
Is there a big difference between WD101PURZ vs wd100PURZ?
Would I run into any issues. I am trying to avoid buying a desktop if this laptop can do the trick.
So far I had no issues running 2 cameras after optimizing:
Optimizing Blue Iris's CPU Usage | IP Cam Talk
Any help without being too hard on me would be grateful.
I would just like to run the laptop and do everything remotely. Anyone have a good post about VM or any other good info?
Thanks
Stats on laptop:
8GB DDR3 RAM
Windows 10 PRO 64x
256gb SAMSUNG SSD
Thanks
