Just bought IMOU's 2x Bullet Lite  and 2x Ranger 2,  to start trying IP security for the first time.
Presently I am doing just wireless to connect, to learn as I got these fairly cheap and may do poe at a later time as we rent.
I am wondering if someone has a recommendation for a 8ch wireless NVR?
I see there are two IMOU wireless NVR's atm,
the white imou NVR2108-W-4KS2 (these may be newer as I don't see these on imou's website, maybe branded dahua in some cases??)
the black imou NVR1104/8HS-W-S2 (cheaper)
There may also be other dahua ones ?
I was looking to get a 4g lte router with sim card such as
Spitz (GL-X750) Smart WiFi | Dual-band Router | 4G LTE
by GL.iNet
For later thinking about a BI server with synology NAS.
I assume I can connect lots of cabled cameras with a PoE network switch to the BI server?
Any suggestions appreciated thanks.
Products need to be compatible in Australia.
by GL.iNet
