Hi guys,
I'm wondering what you guys think is better 8TB Purple HDD, the WD81PURZ 5400rpm or the WD82PURZ 7200rpm?
I've emailed WD also but thought I'd ask the community also.
I will update the thread with WD's response if indeed they respond.
dont play with the heart of your system to save a few bux.Newbie question - Is it okay to buy a used, mfg refurbed or seller refurbed WD Purple drive off of ebay or is it better to source a new one?
The mfg date on a used one is 2017 and the refurbed ones are 2018.
Thanks!
They are way down in price over what they were a year ago.@fenderman - thanks for the advice
@VorlonFrog - thanks, but looking for a purple surveillance drive. Have not seen any special pricing for those.
At Western Digital store today, 4TB Red is $89.They are way down in price over what they were a year ago.
$100 for a 4tb is CHEAP.
Thanks looney2ns for the reality check. As a newbie I've only been looking the last few months so I don't have that price perspective.They are way down in price over what they were a year ago.
Stick with the tried and true purple's.White, red, purple....purple is all I see rated for or suggested here to use for surveillance. I don't know the technical differences though.
