Hello everyone
I bought a Dahua C12 720p Wi-Fi camera, and the user guide in the box said that I should use the "Easy4ip" app on Android. This app no longer exists... it has been renamed Lechange, apparantly, and then later again renamed to IMOU. I installed it and set up the camera, but every time I try to access the camera settings, it says "connection failed". So I'm wondering if you would recommend a different app for this camera? Anything that's simple to set up. I also have no idea what is this camera's model name (some apps ask for it). I tried TinyCam Pro on someone's recommendation, but the app asks way too many details that I don't know.
Thanks!
Thanks!
