- May 3, 2016
- 100
- 13
Too much choice with Dahuas
Here is what I am trying to solve:
I would like to get add PTZ cam to my system, that I could use to check out how dirty/clean my solar panels are and also trigger it to act as 2ndary recording cam for when one of the primary cameras is triggered.
Since I plan to mount it on top of the pole, which I will attach to the top of the roof, I would like to be able to have unobstructed 360 view ability, hence why top of the pole.
IR capability is not important, since, well, it will be useless. So probably Starlight and maybe 10x zoom or so.
Which one(s) should I look at? Don't need fancy AI stuff, so this should be (possibly) less $$$$
