Which NVR would you recommend from the below?
Feb 14, 2021
2
Athens
Hello everyone! New to home security world and forum.
I'm trying to build a security camera system for my home. I don't need more than 4 cameras and the front side one will be 4K, they will be connected to my PoE switch, so i don't need a PoE integrated NVR.
From the 3 listed (available in Greece and most famous around here) which one would you recommend? I need it to have Human detection capability from ONVIF cameras if possible.
-ANNKE N44PAM
-HIKVISION DS-7608NXI-K1
-DAHUA NVR4108HS-4KS3
I also would like to ask, does any of those have the ability to send http/mqtt request as BlueIris does? Thanks in advance!
The reason i don't go with BlueIris is mainly because i don't trust the robustness of Windows system, power consumption and hard-drive encryption (i'm not sure about that tbh).
Apples vs oranges on the HiK vs Dahua. The HiK has NVR capable AI, the Dahua is a budget model that relies on the camera to do AI
That said, always best to match the NVR brand to the cameras brand.
Barely anyone here uses SMD - AI with tripwires and intrusion boxes are far better than any MD or SMD type system.
You turn off Windows updates and the device is better, faster, more secure than an NVR...
Those that run both show with a kilo-watt meter that the draw of the computer can be less.
-ANNKE N44PAM
Welcome @Cameranthropos
"Hello everyone! New to home security world and forum.
I'm trying to build a security camera system for my home. I don't need more than 4 cameras and the front side one will be 4K .. "
Many of us, when new to this also thought "I don't need more than X cameras .. " - and in the end added another one or two .. so think about 2x the number of cameras you think you need as the number of channels you may want on an NVR
i have 5 4mp cameras connected on a 7608nxi-k1 nvr and i get the playback limit exceeded message right after updating the firmware. No other issues during simultaneous playback, instant load of live view, single or multiple playback, event triggering and notification etc. everything works normally. Whats the message about?
Read spec sheet for that model...
You can display / decode 3 or 4 cameras @4MP (30 fps) at once..
-ANNKE N44PAM
What exactly cameras You will use? From which company?
You should choose NVR from the same company as cams...
Mixing vendors creates a lot of problems and missing features...
ps. both HIK and Dahua NVR models are very low-end models with low decoding capability (if you want to display live view from many 4k cams)...
I see the specs, however i don't have any problem in simultaneous live view of all 5 cameras at max resolution and in recording. What is the NVR actually restricting?
Ok i realise that it will revert to a lower quality sub-stream broadcast on live view of some channels if bandwith is exceeded. Is recording also affected if it is set to record in main stream?
No, recordings are stored always from main stream...
This limits decoding capability - for viewing live view or for viewing recorded footage from many cams at once on NVR (over HDMI)...
Reactions: bigredfish and Iras
