which hdd/ssd to add to nvr
trapper
Getting comfortable
Feb 11, 2017
280
275
I have a dahua NVR with a 1tb hdd, I want to add a 6 or 8 tb for 10 camera 24/7 recording of approx 14 day. I don't know much about hdd vs ssd. Is western digital 6tb hdd my best bet or should I go ssd.
HDD is more than sufficient. Most would suggest WD Purple. You really wouldn't see any measurable differences in speed for video pullup between SSD and HDD.
SSDs are not really designed for the continuous writing of video cameras. Sure people have used enterprise ones and can get many years out of it, but more than likely you would get the cheaper typical consumer grade SSD and it may not be able to keep up or you will probably kill the SSD in a year or less like this person has twice:
ssd-hd-failure-2nd-time
As always YMMV and some people have used cheap ones fine.
Size of the drive really depends on your resolution/bitrate/FPS. Use this calculator as an estimate:
Reactions: gwminor48
WD Purple is the best bet. There are some Recorders out there that were built to use with SSD but Dahua isn't one of them. So stay with the HDD that is proven to work best with Dahua.. That is just my 2 cents.. Others will say that they use SSD just fine and they may but the recorders that support SSD were built for them and use a different type of system setup for being able to record to them.
