I am trying to setup a surveillance system on our farm. I am a little bit techy, but not extremely so. I currently have 4 analogue cameras(assorted brands), hooked to an older Lorex dvr in our barn. There is a RG6 coax that runs to the house so I can view the cameras on our tv at night. I also have a Cat5 cable running underground to the barn from the house that is hooked up to a Netgear access point in the barn. I have plugged the dvr into this and can view the cameras on my Lorex mobile & windows apps (using the dvr's ip#) while around the farm. What I am wanting to do is to expand our security system to include a total of 11 hardwired cameras in the barn & 5 others (a mix of hardwired & wifi) around the farm for security purposes-I am hoping to keep the 4 cameras I have for now and use the DVR as an analogue converter to view them on the network. I also REALLY need to be able to see all of the cameras when I am away from home. I don't need anything fancy like motion detectors on the 11 cameras in the barn, but it would be nice on the other ones around the property.
I have done some research, and would like to make the new additions as IP cameras rather than analogue cameras. I'm hoping to put an NVR in the house where there is significantly less dust & moisture than out in the barn as well as better security. I was planning on using the current dvr as an analogue converter to convert/pass the analogue signals along and then add a poe for the rest of the cameras in the barn. I have downloaded Blue Iris as a trial & can successfully see each of the cameras with it through the DVR. I don't want to set up a server in the house to use Blue Iris(I'm not techy enough), I'd really rather purchase an NVR for this job. I have tried setting up the remote/mobile app viewing capabilities of our current DVR, but have run into problems with my ISP. It works fine while I'm on my home network, but it seems the ISP has us behind a CGNAT, and there is no way to access my DVR from the outside world. I have tried using DDNS, VPNs and Ipv6. None will work. Switching ISPs is unfortunately not feasible either as they are the only ISP that offers service here.
With all that said, would anyone have any recommendations for an NVR that will allow me to access it from the outside world without any access to my lan, have hardwire & wifi camera capability, be viewable on my bedroom tv as well as a mobile app, and be relatively easy for me to setup? Alternatively, do you have any other suggestions that would work better for us? Thank you for your help.
