what mount to use for a PTZ camera?
wozzzzza
Pulling my weight
Jan 5, 2015
485
111
i want to get a SD49225T-HN but what mount would i use to mount it to a 40mm square post??
Never mind, I don't think this will go down small enough.
Model PFA150
General
Material SECC
Dimension 130.4mmx170mmx45mm(5.13”x6.69”x1.77”)
Mast Diameter 80~150mm(ɸ3.15”~5.91”)
Pipe Thread N/A
Operating Temperature -40ºC ~+60ºC(-40℉~+140℉)
Humidity 0~90% RH
Load Bearing 10.0kg(22.05lb)
Weight 1.1kg(2.43lb)
Applicable Model Please see “Accessory Selection”
how does the camera mount to that?? or does the camera come with the mount on the top when you buy it??? but not pictured in the website SD49225T-HN | Dahua Technology - Dahua Technology
It does.
cool, if camera comes with this mount then that is all i need, i can easily weld a plate on the pole and screw this to it.
thanks.
No need to weld plate... just use 2 stainless steel clip pipe like this.
that will work as well. being in high wind location i would prefer to weld a plate onto the square pole and screw the mount to it.
