- Jul 15, 2017
- 190
- 49
Why the ROM sizes are different in same mp cameras? If the lens is different does it make any relation to ROM size?
For kitchen & living room area I think dome is the best option but i’m still in learning stage so I decided to learn as much as possible before buying my cameras.Hi Sunny,
Is there a particular reason you want to get a dome version?
What is the benefit of bigger sensor? And the ROM is double than most of the camerasThat sensor is huge! 1/1.9"
Over 1/2" large. Many cams use 1/3" sensors.
Maybe that contributes to cost....
It will have larger "pixels" on the chip, so better capable of capturing light that hits the chip than of a smaller chip with equal amount of pixels.What is the benefit of bigger sensor? And the ROM is double than most of the cameras
How about IR glare in night mode? I wanted to order one dome but Andy said IR glare is a bit problemI have this 8232 dome over my front door.. covered, but outside. Image quality is fantastic!
