What Dahua nvr to buy? Empiretech?
Martin M
Sep 11, 2019
7
5
Estonia
Hello
I saw some amazon reviev on Empiretech nvr and they say it still uses this stupid IE plugin. We are in 21st century, do we have some NVR which works without? I still have Dahua cameras, which use plugin, so I would like to get rid of using some old IE for that and use NVR instead. But if NVRS still need plugins , then what to look? Ideally 8 POE 1080p to 5mp cameras used.
While it is supposed to work with other browsers, keep in mind to ensure full compatibility, IE is still preferred. And this isn't specific to just Dahua either.
It comes down to IE was the most popular browser when these cameras started to be made, so they centered the firmware around one particular browser and they got lazy and never updated the internals of the program to play nice with other browsers as more became available and IE started to fade.
Back when the firmware was written, it was probably a pain to get it to play nice with every different browser, so they went with the most popular one.
They haven't had a need to address this because their intended market (hint it isn't us) is mainly businesses where they have enough light they can stay in default settings so they don't have a need to login to the camera via browser. It is us homeowners that push these to the limits and actually change settings.
So we either deal with outdated browsers but better cameras or go with crap consumer grade cameras that use fancy apps (but probably more vulnerabilities than this plug-in) and modern browsers but horrible images.
A trusted member here wildcat_1, who works closely with Dahua and gets "under the hood" of the firmware, said in this thread:
"Not a case of only using IE for testing, it's more the case that this is the only fully compatible browser (until recent deployments) that truly work with Dahua GUI's. As we've all discussed before, other browsers unfortunately (up to Firefox support most recently) cause anomalies in config, maintenance modes, updates etc. All of this reported back to Dahua to tackle in future but while we all await compatibility with wider browser and platform acceptance OR browser agnostic GUI's, this is unfortunately where we're all at."
So while Dahua claims other browsers are supported, someone that looks at the fine details of the firmware, coupled with many users experience here, that Internet Explorer provides the best opportunity to set up the camera and the setting stick.
Doesn't mean you won't have a problem with another browser, but it is rolling the dice.
Simply use Internet Explorer or Pale Moon and be done with it.
Even brand new NVRs still have Explorer coded into them to access the cameras:
And sometimes you don't know what you are missing by using another browser:
For those that do not know...use IE browser for Dahua (and others?) camera GUI to see more options
I've been using Chrome since I bought my first Dahua camera from Andy last year (the good 'ol 4231's). I was able to log in, see menu options, do the config, save, logout....all done. Always wondered how folks were able to see the AI detection boxes livestream and other stuff which I thought...
Or this one where someone showed that with a brand new 2024 camera model, downloading files from an SD card is 100Mbps with Explorer and 10Mbps with other browsers.
Downloading videos files directly from camera via web interface (using other than IE) seems to be capped at TEN Mbps
UPDATE: If you use Internet Explorer (with plug-in), you can download videos via the web interface at the full 100Mbps speed - note you can't go any faster because the NIC doesn't support GigE. Thanks @TheOtherMike for pointing that out on the data sheet (maybe for 2024, Dahua will go with...
Reactions: Martin M
