IAmATeaf Known around here Jan 13, 2019 3,409 3,375 United Kingdom Sep 23, 2019 #21 Jesus, my garage is just full of junk, worthless junk at that How much did all the GPU power cost or shouldn’t I ask ?
looney2ns IPCT Contributor Sep 25, 2016 16,693 24,877 Evansville, In. USA Sep 23, 2019 #22 I'd stick with the 8ft or lower rule for mounting height. ThomasPI said: Thanks much. What height are cams mounted at? I need 2 cams as well. Click to expand... I'd stick with the 8ft and lower rule...if you want to ID faces. Reactions: ThomasPI
ThomasPI Pulling my weight May 9, 2017 304 212 Sep 23, 2019 #23 looney2ns said: I'd stick with the 8ft or lower rule for mounting height. I'd stick with the 8ft and lower rule...if you want to ID faces. Click to expand... Absolutely, prolly mount no higher than 7’.
