Today I was "playing" with this cam around the door and I'm not really happy with the results.
First I wanted to try out, if the cam fits inside the light fixture next to the door.It fits nicely, though I will have to modify a bit the fixture, to fit nicely.
The fixture is the regular hexagon glasses around the light ball. The problem that I'm facing with this setup is, that I can see the "edges(frames of the glasses)" of the hexagon. This may not be a huge problem, though. I have also tried out without the top metal cover and this way it gets better, since I can slide the cam closer to the glass surface. The frames are not visible this way.
The biggest issues is, that I have a porch, which makes the persons face dark, and the strong sunlight behind the person, makes it unrecognizable.
There are any settings that I should use in this case?
I have tried different backlights, but not helped to much.
