redfive
Pulling my weight
- Apr 13, 2016
- 534
- 229
The issue is that my brother didn't like the voice messages from the VTO in english  .... I have to play a bit on it, for find a solution
.... I have to play a bit on it, for find a solution .... I have to play a bit on it, for find a solution
.... I have to play a bit on it, for find a solutioncan you send meHi there, Today I received the following firmwares from Dahua support France, mentioning there would soon be a SIP version release as well ... :
- General_Multi3_VTH1510_EngItlFreGerDutSpaPor_P_V3.200.0000.0.R.20170826.bin
- General_Multi3_VTO2000A_EngItlFreGetDutSpaPor_P_16M_V3.200.0000.0.R.20170912.bin
And the same day those latest versions from my Belgian vendor :
- VTH151X_EngItlFrnGerDutSpnPrt_V4.000.100B000.0.T.20180906 et
- VTOXXX_EngItlFrnGerDutSpnPrt_P_16M_V3.120.001P000.0.T.20181025
See the difference,
V3.2 for the VTH15xx on one side, V4 on the other side and
V3.2 for the VTO2000 on one side, V3.12 on the other side ...
They both support English (and French for me), both are official, but I wonder why they are not providing the same release, and the difference there is with version 3.2 I actually have ...
Someone has tested ?
Many thanks !
Ciao dovresti scrivere in inglese trattandosi di un forum internazionale...[QUOTE = "RiccardoV, post: 380408, membro: 79048"]
Il supporto tecnico italiano Dahua mi ha inviato questo:
possiamo aggiornare i dispositivi con i seguenti fw:
VTO:
VTH: [/CITAZIONE]
S perdonate la mia ignoranza ma cosa significa SIP e che differenza c'è con quello senza.....io oggi ho installato una versione non SIP e ho notato che il menù e solo in inglese e mancano selle funzioni...
ah ok I didn't know .... thanks for the explanation .... I don't know if it was a coincidence but I having only updated the Internal Unit initially worked well even if I don't see things in the VTH menu ..... then suddenly the external unit stopped working .... I don't know if for this reason but I don't think or anything else.Ciao dovresti scrivere in inglese trattandosi di un forum internazionale...
Comunque sip è un protocollo di comunicazione (lo stesso che usano i telefoni VoIP) e verso il quale Dahua sta migrando tutti i nuovi sistemi da quello precedente proprietario. In un sistema di citofoni devi avere tutti dispositivi sip o non sip, non si possono mischiare.
Inviato dal mio Redmi Note 5 utilizzando Tapatalk
