1) How do I connect directly to it? I am using the camera with a Lorex NVR and I need to connect directly to set shutter speed and so on for LPR.  I used a small POE switch and plugged my laptop into one port, and the camera into the other.  I used the sadp tool  to scan, but couldn't find the camera.  I disconnected from my local wifi network.
2) This camera doesn't show up as a preview in the Lorex NVR, but works fine if you open the camera
3) This camera doesn't work with smart search (probably related to #2) on the Lorex DVR
TIA!
TIA!
