Version 4.1.3
Aug 11, 2014
716
699
In addition to correct a couple of large bugs, this version has a very interesting feature … the Alert list as served to the client apps now sorts each camera’s most recent alert to the top of the list for easy accessibility.
The post Version 4.1.3 appeared first on Blue Iris.
The alert list is missing a comma and breaking the browser's JSON parser ... the result is that BI 4.1.3.0 is incompatible with UI2. I have notified Ken and expect he will fix this right away, then I'll be able to get UI2 updated to be compatible with the other changes.
UI2 is updated and compatible. It will automatically detect the JSON error in BI 4.1.3.0's alert list and switch you over to the clip list. So you won't be able to open the alert list in UI2 until BI is fixed.
