I do recall (wish I could find that thread) that there might be a limitation on how many cameras can share that wire/port.....
Oh boy. That might be an issue then. We were hoping to put 5 on a switch
Is it assigning them separate IP's in the 10.1.1.x range?
Alright, maybe I confused something in my experimenting last night. Trying to add a fourth camera to the POE switch and it's giving me hell. When I hit initialize, I manually set an IP address and it said it successfully initialized. However, in the camera list it still shows the default IP address 192.168.0.108 and won't connect to the camera.It is! 10.1.1.71,72,etc. The very first attempt the initialization failed. So I manually set it to .50 address. But then the rest worked and it automatically continued in the 70s range.
In the camera list the direct connection cameras show "Port 7" or whatever physical POE port they are plugged into. And the cams on the separate POE switch show the "37777" camera port.
