Hi
I have a 2012 (I think) Dell PC running BlueIris. Its Core i3 and 8GB RAM.
Running 5x cameras. 3 Hikvision and 2 IMou Wifi jobbies from Amazon.
CPU sits about 90% and RAM about 6-7GB most of the time but its been like that for years and not skipped a beat.
However, its painfully slow to use the PC itself when I want to change a setting in BI or try to Bulk Delete the recordings from OneDrive so I am thinking it might be wise to upgrade the hard drive to SSD and reinstall everything? It seems slow even with BI closed, like a PC used to feel like 15 years ago and I have reinstalled the OS several times which does little to speed it up.
I don't fancy spending £800 ish to replace it with a new Windows machine as to be blunt, I hate Windows with a passion so would likely just buy the latest Mac Mini M1 and take my chances with the likes of Security Spy.
Cheers
Cheers
