bigredfish IPCT+ Member Sep 5, 2016 37,051 85,314 The Swamp Aug 2, 2025 #61 The only time I see these be wrong like his is when they are manually added vs allowing the NVR and camera to negotiate it autiomatically
bigredfish IPCT+ Member Sep 5, 2016 37,051 85,314 The Swamp Aug 2, 2025 #62 Unplug a cam Delete the entry Plug back in and don’t touch anything. Wait Then try using the IE button (one single left click on the icon) And tell us if it opens? And what the port says You could also try my 1st suggestion and factory reset it while connected using the black button inside the sd card slot The trick on both is to not touch anything do not manual add, let it be and do what its gonna do by itself
B Baldcamman Pulling my weight Jan 7, 2019 314 139 Georgia Aug 2, 2025 #63 bigredfish said: Your switch network settings should look like this View attachment 225792 Click to expand... Yes it does, the thing is the port numbers have always been 37777. Reactions: bigredfish
B Baldcamman Pulling my weight Jan 7, 2019 314 139 Georgia Aug 2, 2025 #64 bigredfish, That worked for that camera, and it does say port19 now. So weird it just started this crap out of nowhere. The camera did not come back online by itself I had to hit refresh. I suppose I need to do all this way now. Reactions: bigredfish
B Baldcamman Pulling my weight Jan 7, 2019 314 139 Georgia Aug 2, 2025 #65 Did the same with all and seems to be working. Thank you so much for your help and time! Reactions: bigredfish
bigredfish IPCT+ Member Sep 5, 2016 37,051 85,314 The Swamp Aug 2, 2025 #66 Yeah refresh is just for those who are impatient It likely connected within a minute or two but the display doesnt refresh that often Glad its working! Reactions: looney2ns
