No, I didn't. We had power issue one day.I always had good results with VGA and USB mouse
Did you update the FW on the problem NVR recently?
Ok, do you mean to remove the Hard disk and reboot without it?.OK, I assume you have powered it down and back up...
Try disconnecting the HD and reboot it
Thank so much for your effort. BUT, solution to remove hard disk and reboot, didn't work. Still the IP for NVR2 is not accessible through web.I have to get some sleep, good luck
No, I have not done that, sorry can you show example of IP configure?.Did you try to change second NVR ip to different one (not used in your network)?
Hello, bigred.The 2nd NVR he said will not fully boot..stuck on logo screen
- I have tried to connect before using monitor, mouse, NVRs, but when I start it, shows the software NVR 4.0, then it stuck. no window for editing configuration.
- Can't login but - When I type 192.168.1.25 on web address, the page cannot be found. When I try to ping 192.168.1.25 -t, it is reachable and working.
- This all started after a power problem
Does it look like This?
Quite possible the power problem he had fried something on the main board.
I had him disconnect the HD and that didnt change anything
Per Dahuawiki
DahuaWiki
dahuawiki.com
- Disconnect, reconnect power and video cables to system.
- Disconnect HDD and boot system. If system boots without HDD, then HDD has failed or is not compatible.
There are following possibilities:
- If Input power is not correct then switch input power.
- If Power connection is not correct then switch power connection.
- If Power switch button is damaged then replace power switch.
- If Program upgrade is wrong then install correct program upgrade or send to RMA.
- If HDD malfunction or something wrong with HDD ribbon then replace HDD or Ribbon.
- If Seagate DB35.1, DB35.2,SV35 or Maxtor 17*g has compatibility problem. Please upgrade to the latest version to solve this problem.
- If Front panel error then replace front panel.
- If Main board is damaged then replace main board.
Hello, steve1225,Third time...
Change IP on NVR2 to different NOT USED IP.
It can be any 192.168.1.10 to 250 but it must be NOT USED...
before check if it used (ping -t <ip_address>)
if ping don't respond, then it should be free.
there is high risk that You have 2 devices which are using 192.168.1.25 on Your network...
this is way it don't respond to the ping...
ps. whether you have Virtual Host option or not, it doesn't matter that you can't connect to NVR itself
