I had a 4MP cam with a 12mm fixed lens watching my driveway. I was pleased with the FOV, but wanted better nighttime images.
I decided to change it out for a 2MP Starlight varifocal,, 2.7mm to 12mm. I figured I’d probably set it to 12mm, for an identical FOV.
I mounted the Starlight in the exact same position as the 12mm fixed cam. However, the FOV is very different. Why? Details below.
IPC-HFW5231E-Z - Starlight varifocal
IPC-HFW5231E-Z | Dahua Technology - Dahua Technology
The varifocal lens is 2.7mm ~12mm. In the pic below, the cam is fully zoomed in, ie: 12mm.
IPC-HFW4431M-I2 - 12mm fixed focus.
This fixed lens camera is available in 3.6mm, 6mm, 8mm, and 12mm.
Aliexpress.com : Buy Dahua Stellar camera DH IPC HFW4431M I2 replace IPC HFW4431D&IP HFW4421D 4MP POE IR80M CCTV camera IPC HFW4431M I2 with bracket from Reliable cctv camera suppliers on Shop1282343 Store
This pic is from the 12mm model.
Q: Why is the FOV so very different?
I bought the 12mm from aliexpress, maybe I received a 16mm lens? I bought my Starlight from Andy.
More info: When surfing into both cameras, the cam's web interface header says "Dahua", unlike some of my other cams. The header on those web interfaces simply says "IP Camera". So I don't think the 12mm fixed cam is a cheap knockoff, with a cheap lens that gives the wrong FOV.
Thanks for any info or hunches,
Fastb
Fastb
