Hello! I have a TVT device that I bricked with an update. I'm trying to reflash it via TFTP, but the firmware I have is .tar, and the request to the TFTP server asks for a .bin file. Is there any way to do this? I attached a picture with the request.
Reading through the log I saw that it looks for a file on the sd-card slot. Could I possibly put the file I have on an sd-card and try to flash it like that? Thank you!
| NPIp>Tdma1 ini_ver 0x30210906 ETH trim = 000012FC speed 000003A4 Non S3 WT dma ok UNZOK! Loader Start ... LD_VER 03.00.03 566_DRAM1_933_1024Mb 12/01/2021 17:21:07 No card inserted Pad driving increased SPI NOR MID=000000C2,TYPE=00000020,SIZE=00000019=>02000000 SPI NOR Q_read 4X tmp_addr 0x02000000 LdCtrl2 0x00000000 Q_read 4X uboot_addr 0x06000000 uboot_size 0x01FC0000 Q_read 4X nodep 0x00103944 NVT_LINUX_SMP_OFFfdt 0x00100000 shm 0x00200000 jump 0x06000000 U-Boot 2019.04 (Jun 16 2022 - 18:07:19 +0800) CPU: Novatek NT @ 960 MHz DRAM: 128 MiB Relocation to 0x07f47000, Offset is 0x01f47000 sp at 07c3fdc0 nvt_shminfo_init: The fdt buffer addr: 0x07c45450 ARM CA9 global timer had already been initiated otp_init! 120MHz otp_timing_reg= 0xff6050 CONFIG_MEM_SIZE = 0x08000000 CONFIG_NVT_UIMAGE_SIZE = 0x00800000 CONFIG_NVT_ALL_IN_ONE_IMG_SIZE = 0x02000000 CONFIG_UBOOT_SDRAM_BASE = 0x06000000 CONFIG_UBOOT_SDRAM_SIZE = 0x01fc0000 CONFIG_LINUX_SDRAM_BASE = 0x01100000 CONFIG_LINUX_SDRAM_SIZE = 0x04f00000 CONFIG_LINUX_SDRAM_START = 0x05800000 MMC: NVT_MMC0: 0 misc_init_r: Firmware name: FW98566A.bin FW98566T.bin FW98566A.fdt.bin misc_init_r: boot time: 225039(us) id = 0xc2 0x20 0x19 0xc2 0x00 STDR256FW with page size 256 Bytes, erase size 4 KiB, total 32 MiB nvt spinor 1-bit mode @ 48000000 Hz nvt_detect_fw_tbin: Boot from flash or emmc Card did not respond to voltage select! Card did not respond to voltage select! MMC interface configure failed Open SD fail: No SD device? device 0 offset 0x10000, size 0x10000 SF: 65536 bytes @ 0x10000 Read: OK nvt_getfdt_emb_part_info: Skip this partition node: partition_fdt.restore mtdparts=mtdparts=spi_nor.0:0x20000@0x10000(fdt),0x60000@0x50000(uboot),0x20000@ 0xb0000(uenv),0x260000@0xd0000(linux),0x160000@0x330000(rootfs0),0x1a00000@0x490 000(app) misc_init_r: boot time: 313346(us) DTS find cpu freq clock 960MHz Set CPU clk 960MHz misc_init_r: boot time: 397084(us) Net: na51089_eth_initialize 1.0.0.1 eth_na51089 Hit any key to stop autoboot: 0 do_nvt_boot_cmd: boot time: 481093(us) NVT firmware boot..... nvt_detect_fw_tbin: Boot from flash or emmc device 0 offset 0xd0000, size 0x40 SF: 64 bytes @ 0xd0000 Read: OK device 0 offset 0xd0000, size 0x1ecec0 SF: 2019008 bytes @ 0xd0000 Read: OK nvt_ker_img_ungzip_linux: not gzip linux nvt_boot_linux_bin_auto: linux_addr:0x05800000 nvt_boot_linux_bin_auto: linux_size:0x001ecea0 do_nvt_boot_cmd: boot time: 698916(us) do_nvt_boot_cmd: bootargs:earlyprintk console=ttyS0,115200 rootwait nprofile_irq _duration=on rootfstype=squashfs ro mtdparts=spi_nor.0 root=/dev/mtdblock6 bo otts=150651,703249 resume_addr=0x00200088 user_debug=0xff Image Name: Linux-4.19.91 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2018912 Bytes = 1.9 MiB Load Address: 00008000 Entry Point: 00008000 Linux Image is at 5800000, uboot fdt image is at 7c45450, loader tmp fdt addres s is at 100000 bootm 5800000 - 7c45450 do_nvt_boot_cmd: boot time: 749721(us) do_nvt_boot_cmd: Uboot boot time: start: 150651 us ending: 703249 us ## Booting kernel from Legacy Image at 05800000 ... Image Name: Linux-4.19.91 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2018912 Bytes = 1.9 MiB Load Address: 00008000 Entry Point: 00008000 Verifying Checksum ... OK ## Flattened Device Tree blob at 07c45450 Booting using the fdt blob at 0x7c45450 Loading Kernel Image Loading Device Tree to 03cf8000, end 03cff0e5 ... OK Starting kernel ... ACTLR: 0x00000004 ACTLR: 0x00000044 Disable MMU Clear MMU Uboot L2 cache aux val: 0x72420000 Uboot L2 cache prefetch ctrl val: 0x70800000 Uboot L2 cache ctrl val: 0x00000000 Done Uncompressing Linux... done, booting the kernel. Booting Linux on physical CPU 0x0 Linux version 4.19.91 (huangyp@frontendserver) (gcc version 8.4.0 (Buildroot 202 0.02.9-10-g744f210)) #1 PREEMPT Wed Dec 22 19:35:24 CST 2021 CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache OF: fdt: Machine model: Novatek NA51089 Memory policy: Data cache writeback OF: fdt: Reserved memory: failed to reserve memory for node 'cma0@0x01A00000': b ase 0x01a00000, size 0 MiB CPU: All CPU(s) started in SVC mode. random: get_random_bytes called from 0x8053c934 with crng_init=0 Built 1 zonelists, mobility grouping on. Total pages: 18288 Kernel command line: earlyprintk console=ttyS0,115200 rootwait nprofile_irq_dura tion=on rootfstype=squashfs ro mtdparts=spi_nor.0 root=/dev/mtdblock6 bootts= 150651,703249 resume_addr=0x00200088 user_debug=0xff Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory: 66940K/73728K available (4622K kernel code, 254K rwdata, 700K rodata, 19 2K init, 164K bss, 6788K reserved, 0K cma-reserved) Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0x85000000 - 0xff800000 (1960 MB) lowmem : 0x80000000 - 0x84800000 ( 72 MB) modules : 0x7f000000 - 0x80000000 ( 16 MB) .text : 0x80008000 - 0x8048ba98 (4623 kB) .init : 0x8053c000 - 0x8056c000 ( 192 kB) .data : 0x8056c000 - 0x805ab954 ( 255 kB) .bss : 0x805ab954 - 0x805d4b24 ( 165 kB) SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 rcu: Preemptible hierarchical RCU implementation. Tasks RCU enabled. NR_IRQS: 384 L2C-310 enabling early BRESP for Cortex-A9 L2C-310 full line of zeros enabled for Cortex-A9 L2C-310 ID prefetch enabled, offset 1 lines L2C-310 dynamic clock gating enabled, standby mode enabled L2C-310 cache controller enabled, 8 ways, 128 kB L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x76420001 novatek_clock_init sched_clock: 64 bits at 120MHz, resolution 8ns, wraps every 4398046511102ns clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x3759f22983 , max_idle_ns: 881590413697 ns Switching to timer-based delay loop, resolution 8ns Calibrating delay loop (skipped), value calculated using timer frequency.. 240.0 0 BogoMIPS (lpj=1200000) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) CPU: Testing write buffer coherency: ok Setting up static identity map for 0x81c0 - 0x81fc rcu: Hierarchical SRCU implementation. devtmpfs: initialized VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 NVTBOOTTS: nvt_bootts_proc_init initial success clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911 2604462750000 ns futex hash table entries: 256 (order: 0, 7168 bytes) pinctrl core: initialized pinctrl subsystem NET: Registered protocol family 16 DMA: preallocated 256 KiB pool for atomic coherent allocations *** nvt_poweroff_setup nvt_otp_module_init nvt_vos: 1.00.003 (Dec 22 2021 19:39:24) *** disable_cnn Get CNN2 Clock error nvt_gpio f0070000.gpio: Register nvt_gpio_probe successfully usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb nvt_i2c f0220000.i2c: Register nvtim_i2c_probe successfully ver:1.00.013 nvt_i2c f0350000.i2c2: Register nvtim_i2c_probe successfully ver:1.00.013 nvt_i2c f03a0000.i2c3: Register nvtim_i2c_probe successfully ver:1.00.013 clocksource: Switched to clocksource arm_global_timer kdrv_builtin_init init module ========== nvt_jpg version: 1.00.007 kdrv_builtin_init init module ========== NET: Registered protocol family 2 tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 6144 bytes) TCP established hash table entries: 1024 (order: 0, 4096 bytes) TCP bind hash table entries: 1024 (order: 2, 20480 bytes) TCP: Hash tables configured (established 1024 bind 1024) UDP hash table entries: 256 (order: 1, 12288 bytes) UDP-Lite hash table entries: 256 (order: 1, 12288 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Initialise system trusted keyrings workingset: timestamp_bits=30 max_order=15 bucket_order=0 squashfs: version 4.0 (2009/01/31) Phillip Lougher jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. Key type asymmetric registered Asymmetric key parser 'x509' registered io scheduler noop registered (default) f0290000.uart: ttyS0 at MMIO 0xf0290000 (irq = 5, base_baud = 1500000) is a NVT nvt_serial: console setup on port #0 console [ttyS0] enabled f0300000.uart: ttyS1 at MMIO 0xf0300000 (irq = 6, base_baud = 3000000) is a NVT f0310000.uart: ttyS2 at MMIO 0xf0310000 (irq = 7, base_baud = 3000000) is a NVT nvt_serial: driver initialized id = 0xc2 0x20 0x19 0xc2 spi_nor f0400000.nor: mtd .name=spi_nor.0 .size=2000000(32M) .erasesize = 0x1000 0(64K) spi_nor f0400000.nor: 1-bit mode @ 48000000 Hz 10 fixed-partitions partitions found on MTD device spi_nor.0 Creating 10 MTD partitions on "spi_nor.0": 0x000000000000-0x000000010000 : "loader" 0x000000010000-0x000000030000 : "fdt" 0x000000030000-0x000000050000 : "fdt.restore" 0x000000050000-0x0000000b0000 : "uboot" 0x0000000b0000-0x0000000d0000 : "uenv" 0x0000000d0000-0x000000330000 : "kernel" 0x000000330000-0x000000490000 : "rootfs" 0x000000490000-0x000001e90000 : "app" 0x000001e90000-0x000002000000 : "rootfsl1" 0x000000000000-0x000002000000 : "all" libphy: Fixed MDIO Bus: probed nvt_eth_env_probe: get IO MEM 0xfd2b0000 nvt_eth_env_probe: pinmux detect emb phy 0x0 DWC_ETH_QOS: Phy detected at ID/ADDR 0 libphy: dwc_phy: probed Supports TSO, SG and TX COE Supports RX COE and GRO PPP generic driver version 2.4.2 PPP BSD Compression module registered PPP Deflate Compression module registered PPP MPPE Compression module registered NET: Registered protocol family 24 ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver nvtim_init_usbhc nvtim_init_usbhc assert reset R0x40=0x30230001 ehci-nvtivot f0600000.nvt_usb2host: usbhc-nvtivot ehci-nvtivot f0600000.nvt_usb2host: new USB bus registered, assigned bus number 1 ehci-nvtivot f0600000.nvt_usb2host: irq 51, io mem 0xff600000 ehci-nvtivot f0600000.nvt_usb2host: USB 2.0 started, EHCI 1.00, overcurrent igno red hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected usbcore: registered new interface driver cdc_wdm nvt_rtc f0060000.rtc: rtc core: registered nvt_rtc as rtc0 i2c /dev entries driver nvt_mmc f0420000.mmc: Using DMA, 4-bit mode sampling Positive edge, mmc0 NET: Registered protocol family 10 Segment Routing with IPv6 sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver NET: Registered protocol family 17 NET: Registered protocol family 15 lib80211: common routines for IEEE802.11 drivers Key type dns_resolver registered Registering SWP/SWPB emulation handler Loading compiled-in X.509 certificates nvt_rtc f0060000.rtc: setting system clock to 1970-01-01 02:30:19 UTC (9019) cfg80211: Loading compiled-in X.509 certificates for regulatory database nvtim_patch_usbhc channel cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 cfg80211: failed to load regulatory.db VFS: Mounted root (squashfs filesystem) readonly on device 31:6. devtmpfs: mounted Freeing unused kernel memory: 192K This architecture does not have kernel memory protection. Run /sbin/init as init process random: fast init done mount: mounting tmpfs on /tmp failed: Invalid argument mount: mounting tmpfs on /var/run failed: Invalid argument mount: mounting /dev/mtdblock7 on /mnt/mtd/bin failed: Invalid argument current times 1 mount: mounting /dev/mtdblock7 on /mnt/mtd/bin failed: Invalid argument current times 2 current /dev/mtdblock7 xtimes 2 chown: unknown user/group root:root total 1157 -rwxr-xr-x 1 1003 1004 29536 Apr 12 2021 ld-uClibc-1.0.32.so lrwxrwxrwx 1 1003 1004 14 Mar 29 2021 ld-uClibc.so.0 -> ld-uC libc.so.1 lrwxrwxrwx 1 1003 1004 19 Mar 29 2021 ld-uClibc.so.1 -> ld-uC libc-1.0.32.so lrwxrwxrwx 1 1003 1004 19 Mar 29 2021 libc.so.0 -> libuClibc- 1.0.32.so -rwxr-xr-x 1 1003 1004 124492 Apr 12 2021 libgcc_s.so.1 lrwxrwxrwx 1 1003 1004 17 Apr 12 2021 libiperf.so -> libiperf .so.0.0.0 lrwxrwxrwx 1 1003 1004 17 Apr 12 2021 libiperf.so.0 -> hydev exist: resume phy [1;32mlibiperf.so.0.0.0 -rwxr-xr-x 1 1003 1004 DWC_ETH_QOS_yinit: apb_clk 120000000 Hz 101208 Apr 12 2021 libiperf.so.0.0.0 -rwxr-xr-x Queue0 Tx fifo size 2048, Rx fifo size 2048 1 1003 1004 927788 Apr 12 2021 libuClibc-1.0.Disabled JUMBO pkt 32.so drwxr-xr-x 2 1003 1004 30 Aug 4 20Enabled Rx watchdog timer 21 modules current no ipcamera exe start update ....Enabled TSO ........ install sdcard driver ............. mount: mounting /Disabled Rx Split header mode dev/mmcblk0p1 on /tmp_run/99 failed: No such file or directory phydev exist: start phy mount sdcard fail ......... start update from ftp : 192.168.0.200 ....... |
