Hi. We have a setup consisting a TVT TD-N064E NVR with 20-odd cameras in our residential apartment block that has sadly given up the ghost after less than 3 years since it was installed by a now defunct subCONtractor of our builder. Does anyone know how to troubleshoot these things based on the beep error codes. We're seeing the splash screen when cycling the main power, but the thing won't boot through to the usual login screen. After a while, perhaps a minute or so in, the box is making 5 longish beeps then nothing. Around the same time, the screen goes dark as the monitor goes to sleep mode. On one occasion I've observed 4 longer followed by one shorter beep.
Also, does anyone here own a copy of the firmware that could be installed via USB in case that helps?
Thanks in advance for any assistance you can provide.
