C Chris J LaBoda Young grasshopper Sep 7, 2019 60 8 Ohio Oct 10, 2019 #1 How do I turn on IVS? Draw rule does not work. Video detection works just fine. Thanks
SouthernYankee IPCT Contributor Feb 15, 2018 5,176 5,342 Houston Tx Oct 10, 2019 #2 Do not double post !
pinko Known around here May 26, 2017 385 623 Australia Oct 10, 2019 #3 Please check to see if you have IVS enabled on the camera Under Event>Smart Plan. You should be able to draw rules once it is enabled. If you cannot, try another browser, Last edited: Oct 10, 2019
Grn1z Getting the hang of it Aug 26, 2019 89 48 Michigan Oct 10, 2019 #4 Check to see if smart codec is disabled. Ivs is disabled when smart codec is enabled.
