Hi Guys
I installed 7 x DS-2CD2332-I caneras around my house a few years ago. I had them working fine through my PC via Blue Iris no problems.
Due to issues with the PC, I decided to get the DS-7608NI-K2/8P NVR. Initially thought I could just plug the camera cables in and away it would go.
When I couldnt get the NVR to recognise the cameras, I did some research on here to find my cameras were more than likely bricked. I used Alastair's unbrick/upgrade method for the cameras.
I have again plugged the cameras into the NVR, but still not getting them recognised by the NVR. Could this be that when I have activated the cameras on my network, I have used IP addresses that are recognised by my router/switch? eg 192.168.1.xxx
When looking at the setup/config if the NVR, cameras ports are assigned a 192.168.254.x address. Due to the cameras having a different IP address, could there be a conflict?
The status of each camera has a "X Exception" in the status column.
Very frustrating, with a lot of head scratching going on....
Any advice greatfully accepted
Cheers
Cheers
