- Dec 2, 2015
- 719
- 251
OK, I was excited to hear that the dropped frame issues got fixed in the latest firmware so I immediately went and set up trip wires around the perimeter of my front yard. I am not 100% that I have set everything up properly or even sure I know exactly how these tripwires are supposed to work as there isn't much for specific directions on these units.
My understanding is that anything that crosses the trip wire will trigger, you have the option for a trigger to activate when said person/object walks from point a to b, b to a or both and also can set the min size and max size of said person/object you want to set off the trigger.
I have mine set to "BOTH" thinking if the the tripwire does not catch the person coming in the yard that it will catch them going out. Not sure if that is how "BOTH" works? Because when I look under the smartview tag I have a lot of triggers and nothing but shadows and cars driving by ( outside my trigger zone ).
-Is there another place I should be looking for these triggers or am I correct to be going to the smartview tab to find them?
-Should my triggers be set up different than what I currently have to avoid false triggers?
-Is there a reason the triggers are not showing in my playback bar via the "web service" interface ( just showing solid green line)?
