Mike A.
- May 6, 2017
- 4,209
- 7,096
Ditto....I use MD just to create some extra zones on cams used as spotters for the PTZ since there is no reporting back to BI for individual IVS zones on the cams I have. Would be nice if BI supported cam specific IVS zones to allow for more customized action to be taken by BI.
I think we can now since we have the different IVS attributes broken out under ONVIF Events. Complicated but under "Listen for:", I think you should be able to disable everything other than only listening for the one type of ONVIF event that you want to pick up for a given ONVIF trigger from the cam (e.g., line crossing as defined by IVS rule #1) . I don't see any way to have more than one set of "Listen fors" at a time for the same cam though so if that's the case then you'd need to have clones to pick up the different triggers from different events.
