- Aug 15, 2015
- 1,335
- 849
Does anyone have any experience utilizing a Touchscreen monitor like an Elo with an NVR? Typically the older touch screen monitors required specialized software, however many of the newer ones run via standard drivers and over vga and usb connection - both of which the majority of all NVR's have.
My thought process behind this is my NVR is currently mounted in a false cavity in a bathroom closet, however I am considering placing a viewing monitor in the mudroom where our alarm panal is. I'm considering a touchscreen so that I could just control everything from that point vs having to log into it via one of our pc's. It would also allow you to very quickly and easily go full screen for a single camera if you wanted to.c
Just figured it was worth researching as I can run 50ft cables to from the mounting location to the NVR without to much issue. From the short amount of research I've done I can't really find anyone that has attempted to do this so either its not possible, pointless, or not worth the trouble in most peoples minds.
