One of my numerous noob questions for the day, and the day is young here
I'm struggling with my pre-conceived budget, which is not as much a financial constraint as a preference of how much to invest. To enable a greater spend on cameras I am investigating the lowest cost, workable option for an NVR. I'm looking at a NVR4116HS-4KS2 which states a record rate of 80Mbps, has only a 10/100 connection, is a simnle SATA model... but is H265. I only have around six to eight H265 cameras on my shortlist and they are spec'd at around 6Mbps maximum.
So if I was to work on the highest advertised bitrate for a selection of cameras, how close to the advertised throughput of a DVR would prove reliable? As the subject NVR is a non-PoE unit and as such I will need to use a switch, how close to the Interface limit of the NVR would be reliable if the distance between the NVR and the switch is kept short?
I might never add any extra cameras. However if I did they may be some higher pixel density units for daytime detail... and I'd like to have an understanding of what is likely to occur as I approach the NVRs limits, and how much to derate the specs.
Cheers,
Steve
Cheers,
Steve
