- Apr 21, 2018
- 3
- 0
I have a 3 year old unit which until a couple of weeks back was working fine. It is now stuck with a NVR splash screen and a swann logo stuck on the bottom right hand corner.
Problem started when the recorder was not seeing 2 of the cameras. I decided to reboot it in the correct way and that was the start of my problems .
Swann technical are referring me to a CCTV specialist. So I thought I'd give you guys a try to may be steer me in the right direction.
The unit shows a green power light and that's about it.
I disconnected the cameras as well and try booting however no luck.
Hope you can help to resurrect this £800 tin box.
Thanks in advance.
Thanks in advance.
