- Dec 24, 2016
- 410
- 320
So, I made a STUPID mistake installing the two cameras that cover the doors/windows overlooking my patio. The picture attached shows the situation. The two walls with windows/doors form a corner. It is about a 20ft x 20ft area.
I mounted a camera to the side of each door, zoomed in to cover the opposite door.
Works great in the day time, however I completely flubbed this and didn't consider the fact that the camera's IR emitters are visible in one another's field of view.
I can probably re-aim one of the cameras to compensate, but for the other I wanted to cover a bit of the most likely point of approach, so its inevitable to have it in view.
I'm thinking my best option is to get an IR emitter (flood, or two more directional ones) and put it off-camera in the corner somewhere, illuminating the patio that way.
Its either that or move the cameras, but I would prefer not to do that.
