I finally started mounting three sample cams I received from Andy, one of them is the ultra starlight. To cut a long story short after countless hours of struggling I narrowed the problem to the following issue:
- when this cam is connected to longer network cable (around 23 meters long) it is working unstable, ie BlueIris reports loosing signal and my Cisco even does not detect the camera and I need to connect it via simple asus switch
- when this camera is connected via short cable (around 2 meters long) everything works like a charm
What I already did:
- tested 3 different power supplies (I do not use POE), finally I also tested it on a dedicated "lab like" power supply
- tested 3 different long network cables with same result - camera not working properly, same network cables are working with other devices, additionally I bought and tested them with network cable tester https://yalu.pl/15968/tester-kabli-rj-45-i-rj-11-rg-58-gembird-nct-3-z-wyswietlaczem.jpg
Anyone any ideas? I have none what to do now ...
What I already did:
