stored video folder size over quota?
Coal_Cracker
Pulling my weight
Aug 21, 2022
123
223
USA
I've had an ongoing problem for a couple months now and just haven't had much time to address it, BI keeps telling me my stored video drive is over quota. I've deleted all files from the drive multiple times and even deleted the folder and tried using a new folder but with the same results. I also tried using a earlier version of the release but it made no difference.
Provide a screen shot of Blue iris status (lighting bolt graph,upper left corner) clip storage tab.
Did you rebuild the BI data base after you manual deleted the BI video files ?
My Standard allocation post.
1) Do not use time (limit clip age)to determine when BI video files are moved or deleted, only use space. Using time wastes disk space.
2) If New and stored are on the same disk drive do not used stored, set the stored size to zero, set the new folder to delete, not move. All it does is waste CPU time and increase the number of disk writes. You can leave the stored folder on the drive just do not use it.
3) Never allocate over 90% of the total disk drive to BI. Leave at least 50GB free.
4) if using continuous recording on the BI camera settings, record tab, set the combine and cut video to 1 hour or 3 GB. Really big files are difficult to transfer.
5) it is recommend to NOT store video on an SSD (the C: drive).
6) Do not run the disk defragmenter on the video storage disk drives.
7) Do not run virus scanners on BI folders
8) an alternate way to allocate space on multiple drives is to assign different cameras to different drives, so there is no file movement between new and stored.
9) Never use an External USB drive for the NEW folder. Never use a network drive for the NEW folder.
10) for performance do not put more than about 10,000 files in a folder, the search and adding files will eat CPU and disk performance. Look at using a sub folder per camera (see &CAM in bi help)
Advanced storage:
If you are using a complete disk for large video file storage (BVR) continuous recording, I recommend formatting the disk, with a windows cluster size of 1024K (1 Megabyte). This is a increase from the 4K default. This will reduce the physical number of disk write, decrease the disk fragmentation, speed up access.
Hint:
On the Blue iris status (lighting bolt graph) clip storage tab, if there is any red on the bars you have a allocation problem. If there is no Green, you have no free space, this is bad.
Advanced storage:
Hint:
Honestly, It was over the summer I'm pretty sure I did but now I can't 100% remember.
I repaired the DB again I guess I will see If the problem returns. last time it was okay for awhile but returned after a few weeks.
Advanced storage:
Hint:
Thanks for these instructions. I have a NUC which only supports SSDs or external USB drives and you recommend to use neither one of them. I have a partition of the SSD configured as D: for Blue Iris only. Do I just have to live with this setup if I don´t want to exchange the NUC for another PC?
