Hi,
I've some question regarding hikvision nvr.
I suspect some wrong configuration on nvr.
2 weeks ago, bit rate was set to 2048 and frame was set to 16.
Now the value is 6144 and 20.
I would like know the impact because the next day after this change my nvr was crashed (not live view and web page wasn't more accessible. The only solution was restarted the nvr.
I saw on the documentation that the bitrate define the maximum size for one hours per channel.
I've 3 nvr on different locations.
first location has 5 ip cam, second location 3 ip cam and third location 4.
System is configured to record only when the system detect a move and each nvr has 1 HDD of 1To
Thanks for your clarification.
Regards,
Michel
Regards,
Michel
