I am struggling with the integration of some Pakedge/Lilin CK-CAM-TU652 cameras with the Hikvison NVR DS-7608NXI-I2 / 8P/S. I try to add with ONVIF but nothing happens. All I get is "Offline(Network Abnormal)" I have enabled ONVIF under Network -> Advanced Settings -> Integration Protocol. Im not familiar with ONVIF but I made a user with the same username and password as the camera.
Im not sure where to start troubleshooting this. Is there a way to integrate the cameras with RSTP instead, using a custom profile? I know my Control4 system can use the RTSP stream directly using rtsp:/10.0.2.61:554/rtsph2641080p but not sure how a custom profile would look like?
Anyone that could help me out here?
Thanks!
SOLVED. My inexperience with NVRs was that it didn't have DHCP and therefor each camera needed static IP before being added to the NVR.
Thanks!
