Hi, I have found a strange issue and wonder if there is a fix available..
In the IP Cams (mini black face and startlight turret) I have set the timezone to PDT (UTC -7), and I can see the timestamp on the image is correct.
However, when Gmail receives the alert email from the camera, it shows that it is from a UTC+8 timezone ( the default timezone set in the camera)
Is there some where I can change this secret timezone setting? Or is there something else I done wrong?
here is the relative line in the Email header, and attached the setting page and timestamp on camera capture:
Received: from localhost ([good_IP_address])
by smtp.gmail.com with ESMTPSA id k198sm19177412pga.54.2017.04.23.21.57.35
for <[email protected]>
(version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128);
Sun, 23 Apr 2017 21:57:37 -0700 (PDT)
Message-ID: <[email protected]>
Date: Sun, 23 Apr 2017 21:57:35 +0800
Any pointer? TIA!
Any pointer? TIA!
