Thanks! Will try that today. Although to be honest, I have shortened the timeline to less than an hour before, but do not see a red flag to move, on the right. I will give it a go, again. Much appreciated.When you use the cut tool you can see the 1hour red flags. You can then slide the right side flag,
( at the end of the hour) and slide it to a shorter time. Then click the cut tool again.. All as mp4
You will have to expand the timeline to get the minute view.
I was able to do a 30 sec clip to 10 mins with nos issues.
Right again. The initial timeline has to be 1 hour or more to see the right flag. That was my problem. Works like a charm. Thanks again.If you dont see the red flag on the right, you will have to compress the timeline to see it. It will be at the 1 hr mark.
It is a pain everytime and if you forget, it starts to download the 1hr clip. It has been working for several versions.
Do you get push notification from gdmss plus for IVS triggered? It seems to be broken. I can see the log and event from the NVR but not getting the notification sent to my phone.IVS config directly on the NVR, on the cameras seems ok
