Hello fellow IP Cam users,
I recently got introduced into a SmartPSS system with cameras and everything setup, however my task was to investigate why it is lagging.
What they meant by lagging was the CPU being tanked at 100% when the Live View cameras were viewed in a 4-way camera split.
After fiddling about with SmartPSS I have found out that changing the view to a 9 way split has 'fixed' it and the CPU is sitting at 20-30%.
Also tried doing a custom 6-way split view and the CPU was still fine, barely topping 40%. I have noticed that when you change the split the resolution of each camera/window gets changed.
Please excuse my lack of knowledge on this software (and IP cameras in general) however I am pretty sure the resolution of each camera window in the 4-way split needs to be toned down, however I couldn't find a way of doing so.
I appreciate any suggestions and possible fixes.
Thanks in advance.
Thanks in advance.
