SmartPSS -frame search - anyone got this to work?rame search in playback.
psycik
Dec 9, 2015
230
43
Wellington, New Zealand
The smart pss software has a frame search In The playback section (that blue looking glass). You seem to draw a box, then search.
I've never had anything work. I assumed it's a motion search. Is this correct? Anyone got anything useful out if it?
ive played with it on the NVR, highlight / box the area you want to search and press play. It should only show file segments with motion in the highlighted area. As for smart alerts, Ive only had motion detection so far..
Its great for doing a quick search of a particular area such as end of driveway or front door instead of going thru every motion file if you have other things that normally setoff motion such as shadows or birds in specific areas..
I think it also has to have detected motion "md" within that area that is selected. if motion didn't trigger a record event I don't think it will show. I may be wrong. p
Since your recording 24/7 anyway setup motion detection also. It won't use anymore had space but will give you a mark on time line anytime motion is detected.
