Dahuacamcctv
Use DSS express its a newer version of SmartPSS and has its own mobile app. I got it through a member on the forum though I think you can get it for free from Dahua.
 -Are you actually using this software?Use DSS express its a newer version of SmartPSS and has its own mobile app. I got it through a member on the forum though I think you can get it for free from Dahua.
The DSS server is like PC-NVR you can run the client on the server.-Are you actually using this software?
-It seems that it works with a client/server architecture so the client won't work without a server (DSS Express Video Management System Server – Dahua North America), am I wrong?
Ok great... Where do we get it from? Thanks!The DSS server is like PC-NVR you can run the client on the server.
Glad changing the port setting worked for you. Unfortunately, it doesn't seem to work for me. I have the behaviour with the HDD Manager tab not responding even after changing the port (tried 37778 and 37780).Have you tried to change the PC-NVR default port? I set it to 37780, only after that I had the possibility to obtain information about the disk and the nvr. Probably there is some port conflict on the 37777
I cannot deny that this software doesn't appear too much functional but it should be. For me, it's impossible to use the 37777, I hope this change solve the problem for a long time period
While you cannot gather information about the hdd manager on the nvr tab, is your nvr recording?Glad changing the port setting worked for you. Unfortunately, it doesn't seem to work for me. I have the behaviour with the HDD Manager tab not responding even after changing the port (tried 37778 and 37780).
I can answer this. I installed the newest version of smart-pss and changed the port to 37785 and it does record believe it or not. You cannot go into the hdd manager and do anything because that portion is not functional but it does indeed record.While you cannot gather information about the hdd manager on the nvr tab, is your nvr recording?
For anyone who was looking for DSS EXPRESS, this is the folder directory from which you can download the server version. Actually, I just installed the package but services are not started so I cannot say something about the functionality of this software yet, hoping anyway it is better than SMARTPSS.Ok great... Where do we get it from? Thanks!
I'll tried to add two different Dahua NVR's to DSS Express and in LiveView DSS Express says "Request Timeout", but in the GDMSS Plus they works at same time. Tried different users / logins - same error. But single IP cams works fine. I think, there is a restriction on addding NVRs to DSS Express or something elseAnyone know if this one will keep the connection to the NVR?
