Does the micro have both an NVME and a 2.5" bay inside? I'm thinkin maybe not,,,,,so maybe you transfer to an external 2.5 SSD?
Sounds promising. for smaller systems
I use one of these with 6 cameras and no issues whatsoever.
I have 16gb ram. OS and initial recordings on a 512GB NVME SSD, and after a week recording are moved to a 500GB 2.5" SSD.
Buy HP EliteDesk 800 G5 Mini Intel i5 9500T 2.10GHz 16GB RAM 256GB SSD Wi-Fi Win 11 | ACT
Buy Refurbished HP EliteDesk 800 G5 Mini. Intel i5 9500T, 16GB RAM, 256GB SSD & Wi-Fi. 12 Month Warranty & Free Shipping AU Wide. ACT - Australia's largest refurbished computer retailer. Shop Now!www.australiancomputertraders.com.au
You will have issues with external USB... Modern desktops use very little power You're not saving anything by having a tiny machine except making it very easy to walk away with. Get a machine that allows you to incorporate proper 3.5 storageThe tiny G4 800 micros actually have 2 x NVME and a 2.5-in thin (7mm) SATA bay. I'm thinking of putting a 1TB laptop SSD in that bay. Another option is a 4TB USB 3.0 external hard disk (because I have one lying around).
MUCH better solution. HP EliteDesk 800 G4 i5-8500 3.0GHz 8GB RAM 256GB SSD Win10 Pro SFF Desktop PC | eBayThank you everyone. Any thoughts on this one MINISFORUM EliteMini HX90 Mini PC AMD Ryzen 9 5900HX Windows 11 Pro Desktop Computer, DDR4 32GB+512GB SSD, 2.5Gbps LAN, 2X HDMI & 2X DP 4K@60Hz Outputs, 2X HDD Slot, AMD Radeon Graphics Tower PC
Maybe keep it for a rainy day project. and get a SFF?
You should look at optimising some of the BI settings as my i5-9500t hovers around 8% cpu utilisation with 4 camerasUnfortunately, it was a case of me being too hasty... I intended to buy an SFF HP like @Flintstone61's PC and the one @looney2ns just mentioned. But I accidentally bought a micro-SFF version of the HP instead.It also comes with a laptop i5-8500T (instead of the standard i5-8500) which could be a bottleneck if performance demands go up.
But so far, it's doing well with 4 cameras demoing BI as I learn the basics of it (and IP cameras in general). It's hovering at about 25% CPU and 1.35GB of RAM according the the BI info line at the bottom.
Its important to not that the number of cameras is irrelevant. 4x8mp cameras at 30fps is very different than 4x2mp cameras at 15fps. Add Codeproject AI to the mix and you have a very different outcome. Or if you want to use 2mp substreams instead of D1.You should look at optimising some of the BI settings as my i5-9500t hovers around 8% cpu utilisation with 4 cameras
