I do plan to have a separate POE switch in there, and a patch panel to home-run everything into. I just can't tell with the dimensions if there's room built into the door for cabling or not.At first I thought you maybe able to get a power cord with a 90 degree bend... however I think that still is too thick...
https://www.amazon.com/Tripp-Lite-Enclosure-Switch-Depth-SRW12U/dp/B009B1I1C8/?tag=ipctk-20
If you want to install that model NVR and use this enclosure I would mount 2x4s on the back as stand offs and that will give you another 1.5" - which would be good for the power cord.
For the ethernet cables - it still is very tight imho - so probably a separate PoE switch which is shorter in depth.
